Re: Pickup Coil
the pickup coil in the dist. Changed and started right up. After about 5 to 10 min. it died again. What could be the cause?
Tim Bell
For carbureted engine models, The proper name for the sensor mounted under a Mercruiser stock OEM distributor cap is "ignition sensor". A "pickup coil" is used on older EFI engine models. Older EFI's also use a "ignition model" mounted under a OEM distributor cap where your ignition sensor is located.
The most common things that could keep damaging the ignition sensor are, voltage spike within the ignition system, bent/loose rotor hitting the ignition sensor, or wobble on the distributor shaft allowing the rotor to hit the sensor, Bad ground.
Make sure you battery cables are clean and tight at both ends to avoid voltage spike. Also check your alternator voltage with a multimeter.
Good luck.
