Hello all,
I have 1998 255CC Sea Pro w/ twin outboards.
Engines are 2004 MERCURY Carbureted Saltwater 200 HP CXL SW.
One of the outboards (Serial No. 0T816342, if you need more information) was leaking trim fluid from the power trim pistons, so w/ the help of a friend I bought a repair kit, took it down from the boat and replaced all the o-rings, screws, etc.
We put it back together and for the last 2-3 days (!) I have been in the process of adding the fluid/bleeding the air out and making sure it works as it should.
I have tried several procedures:
1. Trim it all the way up
2. Remove the plastic screw and add fluid till it starts to go out.
3. Do not close the fluid opening and trim down/up for up to 30 mins-40mins in order to get rid of the trapped air
=> Didn't work
3. Close the fluid opening and trim down and up.
4. Remove screw to let air flow out every time it is on the up position.
5. Repeat for 30-40 mins !
=> Didn't work
3. Close the fluid opening and trim down.
4. Use the manual release on the side to let the air escape.
5. Trim up.
4. Remove screw to let air flow out.
=> Didn't work
I uploaded a video so you can see my problem. Please let me know what am I doing wrong. What is the correct procedure to fill the trim fluid/ bleed the air out?
Here is the link to the short video (made w/ my phone, sorry for quality issues):
Power Trim Issues on 2004 Mercury Outboard 200 HP - YouTube
Thanks!
=> Didn't work
=> Didn't work
5. Trim up.
=> Didn't work
Thanks!
