Re: Normal and max backlash of Commander 2000's fast idle and main levers
A year or so ago I put in an new 2000. Fast idle is right on the money.....move it and the rpms change. Pulling all the way up to the highest idle speed is a bit variable, but the control is new and needs the edges worn off. Going down it is rock solid.
Single shift/throttle lever is designed for slop in the throttle giving time for the shifter mechanism to engage. So 30 degrees of movement of the handle with no speed increase is about right.
I bought mine here on iboats.
Want more, ask,
Mark
