Hello I am new here. I have a question in regard to my boat I just purchased. I purchased a 1991 Four Winns and it has the 2.3 L cobra in it with the cobra outdrive.
The drive would not shift into forward and only had reverse, I took it to my local marina to have them adjust the shift problem and all is well. Now the problem is, I can sit in neutral and the engine will rev up like no other and run good, but when there is actually a load the engine wont go over 2,000 RPM WOT.
Someone said to check the points and condensor as this could cause it? Any information would be greatly appreciated.
