mbh1970a@yahoo.com
- Jul 8, 2013
- 11
Boat runs great until you run it awhile and stop for awhile to fish for an hour or so then it will not start, i posted this on here before and was told that it may be flooding and to rebuild fuel pump so i did and it still did the same thing so i rebuilt carbs and tested yesterday except this time i took spark tester with me. I rode up the lake about 5 miles ran better than it ever had cause when i rebuilt carbs i noticed one carb shutter was not closing all the way and both was not opening all the way and man what a difference it made on take off to have full throttle it has been like that since i bought it new, also does 50 mph now instead of 46 mph, any way when i slowed down to turn around to come back it died like you turned the key off and would not start so i checked for spark and did not have any on all cylinders. i started looking at harness wires but did not see anything wrong and checked spark again and had spark. drove the five miles back to landing at different speeds no problem ran like new. got to landing cut off and fished for 30 to 45 mins and guess what no spark again. never got it to spark so i trolled to landing and loaded it up. i get up this morning and it has got spark. I was hoping it didn't so i could check the yellow and black cut off switch wire. I cheked compression all cylinders have 120 psi. I hope this post is not to long trying to give you all the info i can. Boat looks and runs like new i really want to fix it please help. IMAG0027 | Flickr - Photo Sharing!
