Does an engine bracket heve to be removed or loosened to be able to remove the tilt and trim assembly from a Yamaha 150 HPDI? I have the unit loose, but can not get it to move up or down and I am thinking that it must be mounted inside the engine mounting brackets on the transom. Is this correct?
