Townes0616
- Aug 22, 2013
- 3
Hello,
This is my first boat bought used from neighbor who believed it to be in good running order.
Here is the problem... when I accelerate at about wake speed or a little faster the boat does 1 of 2 things. 1. It will either all of sudden engage and take of like it was starved for gas and then all of sudden got a shot of it or 2. it will bog down and the motor will die. The problem seems to be worse when the load on the engine is more and I say that because it will not have this issue if the boat was still moving from slowing down or if I trim the motor up when accelerating. If the motor catches it runs fine for as long as you want.
Here is what has been done so far:
1. Compression test 125, 120, 120.
2. Leak down test passed.
3. Carbs completely rebuilt.
4. New spark plugs gapped and heat rated for motor.
5. New fuel pump, line and gas tank
6. Timing checked
The mechanic has told me that there is a possibility the cylinders have an egg shape at exhaust port and this will cause motor to choke under big load, but several people have suggested that it would not have had good compression and would fail a leak down test if this was the case.
My next plan is to lower the pitch on prop and get another year or two from motor.
Any suggestions or ideas would be greatly appreciated.
:joyous:Thanks
6. Timing checked
:joyous:Thanks
