Re: spark plug recomendations?
Surface gap plugs are designed and spec'd primarily for sustained high speed running. Some owners that extensively troll at or near idle have changed to a standard electrode gapped spark plug such as the NGK B8HS or B7HS which is very near the same heat range.
Prior to any change in plug design check spark plug to piston clearance to ensure at least .080 between the tip of the ground strap and the piston.
Some motors have sufficient clearance to run an extended tip plug such as the NGK BP8HS.
If you are having problems with plug fouling it may not necessarily be the spark plug causing the problem. Carb cleanliness, float level adjustment, leaky needle/seat, can over fuel and prematurely foul/kill a set of plugs.
Are you having a problem, and if so, what have you checked, or done so far?
