My problem:
I have 12volts going into the ignition switch when the key is in off position. As soon as I turn in to accessories it goes down to about 3.5 volts when switched to accessories and then down to 0 when it is switched to on.
I have checked and fully charged two batteries to test this and always they read 12 volts.
I have overridden the neutral/safety switch.
There is 12 volts at the starter solenoid when the key is in off position but again goes to about 3.5 volts when switched to accessories and then 0 volts when in the on position.
There is no clicking or attempting to turn on when the key is turned on.
I have put jumper leads from battery to the starter motor and it turns over so the starter motor is not the problem.
I am in the process of purchasing a replacement ignition switch.
Is there potentially any other problem that could be causing this?
Thanks for any help given!
