fuel pressure stays 34lbs to 33lbs when above idle speed.no water in fuel, just want power up, everything checks good first time i've been stumped but sure it will happen again.
Thats the supply before the high pressure pump and around 35 psi is ok. The high pressure for the direct injection is only displayed on the laptop software and should be 750 to 1000 psi depending on model[/QUOTE
FUEL PRESSURE ON LAPTOP WHILE RUNNING ABOVE IDLE SPEED IS 945LBS
