Please help... I have a 1998 Reinell 200c with a 5.7 liter mercrusier and a alpha one outdrive. Stock everything.
I bought the boat from a guy who told me it was rebuilt and had less than 5 hrs on it. The boat started and ran fine on a hose and so I made the purchase. We took the boat out and under load at 4400 rpms it began to backfire through the carb. Checked plugs wires timing etc..... Here's where it gets good. I pulled the plugs out and the number 5 cylinder looked like it wasn't firing. So I cranked the motor a few times without the plug in it and then put the plug in the wire and up to the block to check for spark and it was sparking. Took the boat out on the water and it ran like a champ.. No miss no backfire. idled perfect all day and ran like a brand new boat!!!
Loaded up the family today for another night on the boat. Got 2 minutes into our trip and the motor starts backfiring and missing so bad it wont stay running at all. It wouldnt even start. So I figured it was valve related? maybe a stuck valve? So I pulled the number 5 plug and the cylinder behind it and cranked it over a couple times. Checked that the plugs were firing and put them back into the cylinders and the boat started right up. Still running rough but it limped back to the dock......
Is this a valve issue? Why would it run perfect for 5 hrs and then the next time out (3 days later) miss backfire and stop running?
Please help! Thanks Guys!
