Re: Two year old fuel?
Hello,
I recently purchased a used boat that has been sitting for a couple of years. We took it out for a test ride and it ran fine. My question is that it has 3/4 of a tank in it and would it be ok to continue to run that fuel or should it be pumped out and replaced?
Thanks
Howdy,
Welcome aboard!
2 year old fuel will have lower vapor pressure (due to the higher end hydrocarbons evaporating out)
This can cause any engine to be hard starting because it doesn't vaporize well in the carburetor......Although It's not as much a problem in an EFI engine.
Also, the octane can be quite a bit lower which can result in detonation. A single detonation event will usually destroy spark plugs and can even burn a hole in a piston.
You can probably run the fuel, but I would dilute it at least 50:50 with fresh premium or mid grade gasoline. ( The difference in price between regular and premium is usually no more than about 10% higher than the regular.)
I would replace the dist cap, rotor, points/condenser(if installed) and spark plugs on "general principles"
Make sure you change the fuel filter/water separator. (if it doesn't have one, you should install one)
Regards,
Rick
