2-stroke oil hoses what to use?
lime4x4
On my 87 yamaha's 150 2-stroke i need to replace the oil feed hoses from the remote tank to the tank on the engine. I also would like to replace all the hoses that go from the oil injection pump to the cylinders as well. And i guess while im at it i want to replace the oil fill hose from the gun wall down to the remote oil tanks. What type of hose or hoses do i need?
Bamaman1
Re: 2-stroke oil hoses what to use?
It would probably be best to go to a Yamaha dealership and purchase the hose from them. All rubber hoses are not created equal, and they're not expensive parts. Or, order the hoses on IBoats.
lime4x4
I found the hoses that go from the pump on the engine to the cylinders. I need the hoses that go from the remote tanks to the tank on the engine and i also need the oil fill hose from the deck fittings
