I changed the heat exchanger from the 3" to the 4".
The engine does run a bit cooler and does cool down much faster with the 4" heat exchanger.
I am running about 180 at 3/4 throttle. Is that normal?
I did notice that at some moments when i did go 3/4 throttle the engine temp would go up to 180 then back down to 160 and stay there.
I don't understand...any help would be appreciated.
Thanks.
Thanks.
