I have a bass boat with a vmax 250. the motor starts right up but after we run down the lake turn off the boat sometimes it will not start back up almost like it has no gas. We took it to get it fixed and they replaced the ignition switch which didn't help. it sounds like a fuel problem to me. I took it to a buddy to fix and he found a leaking gas line at the bottom of the outboard. Do you think this could fix the issue? also when you takeout of the water hook the muffs up to it, it starts right up everytime. It has shut off in mid run a couple times
