starcraft bahama
- Aug 16, 2013
- 5
I purchased a 1968 starcraft Bahama recently, it has been in storage for 45 years! It has a 40 hp Johnson Electramatic. When I got it home I rebuilt the carb and fuel pump and it purrs perfectly! Changed the lower unit lube with type "C". Water pump pumps great. Rewired from just behind the harness to good wires forward as the insulation was falling off the wires. So... here is the issue....It shift perfect into reverse and forward, but when trottling up it jumps out of forward gear. After warming up it doesn't seem to do it as often if at all. The voltage meter doesn't move either I keepa battery tender on it when not in use. Is it wiring issues or voltage?
