So I took apart my motor at the carb to look at it after I hit a log to make sure the adjustments were still good. I noticed vacuum lines off my cut off switch were dry rotted along with another vacuum line making a total of two. So my question is after hitting a log my boat feels like it is bogged down at WOT could it be because of those lines, could the flywheel have slipped and knocked off the timing, I still have to test the prop in the water to see if its a spun prop was just wondering if I should check the flywheel, and replace the lines
