I have a 1988 Mercruiser 3 liter 4 cylinder with an alfa one leg, I took it out yesterday it had not be run for 18 months, it started fine with a new battery. I went out for about 20 minutes cruising at about 25 mph, and first I noticed the tacho had stopped working but all other gauges working fine, within a couple of minutes with no warning the engine just cut out. I tried to restart the boat but nothing, it just turned over but no attempt to fire. I checked the coil lead to the ground of the engine but no spark. After approx 1 hour of trying different things I had given up.
So I called a towing company, 2 minutes later my 5 year old son kept on turning the engine and…it fired and then started to run! I managed to get back to within 500 meters of where I launched the boat and it cut out again and will not re start. At home yesterday I changed the coil out but still no spark.
Any direction please.
