First post on the board. let me tell you my story and where I'm at in the process. I have a 1995 Cobalt 220 with a 2007 5.7 l volvo penta closed cooling. Boat has been running fine. Took to the dealer to have lower unit serviced and check a slight water leak at manifold/riser connection. Repairs made-serviced lower unit,replaced exhaust manifolds and risers, replaced spark plugs,replaced stiff shift cable. Picked up boat last week and when home engine would not start. Called dealer and was told it ran like a top before pickup. Took back to the dealer and it would not start. Was getting fire,fuel pressure good, replaced distributor cap. Still would not start and when ignition was turned off engine would go in reverse slightly -no water applied here, muffs when I tried starting at home. Worried about hydrolock. Dealer still has boat. Please any advice as to what should be done. Thanks
