IQRaceworks
- May 20, 2012
- 37
I finally got a chance to take the 99? Crownline 248 BR I bought out for a long run this weekend and really test it out. The 7.4 MPI ran like a top?.I?m very happy with the motor and Bravo III drive it?s got.
The one thing I noticed was that the water temp gauge would seem to fluctuate and between 170-180 depending on if you were idling, or running fast. I did a fresh oil change on the motor and water pump impeller before I took the boat out, so I know everything should be in good shape. It may be a problem with the gauge because I noticed that when I would turn the blower on, or switch some other accessory on for a second?the needle on the temp gauge would jump up just a hair?..turn the blower off, and the needle on the gauge would drop back down.
What?s the normal operating temp this thing should run? At wide open throttle?it seems to stay right at 175 on the gauge, but then at idle everyone now and then it would creep up to around 180, and then it would go back down to 170. Sometimes pulling a wakeboarder it would creep up to around 180 or so also. Is that normal? Should I replace the thermostat? If so?what temp?
Thanks!
Thanks!
