Got a 1967 200 series Mercury Kiekhaefer 20 hp serial # 1906997, was sitting for 5 yrs just got it back from brother. So I went through the checkup and maintenance on it and change the water pump impeller right away. Put the lower unit back on made sure brass tube fit into plastic sleeve on water pump. Dropped the motor in a barrel, no water flowing from tattletale. Pulled lower unit back off, tried air compressor blowing up through the brass tube and got nothing. Pulled fresh water flush screw out and brass screw out from top of engine got air flow through both. I don't have a bib to turn into the the flush side to connect a water hose to it, so i just spray water up it with one of those small brass pressure tips. got water flowing out the brass lower unit tube and the top of engine, still nothing from pee hole. Took some weed trimmer line like someone in this forum had said once, only goes into tattletale 3 inches. So whats next, pull port side of engine cover off ?
thanks for any help you all can offer.
One extra thing while I had it running in the barrel I noticed it didn't run at full rpms, Can't have anything to do with water flow, might be one of the coils not firing but that's another matter.
