Hi guys,
I have been having this problem with my boat for the better part of the season. When im out trolling the motor stays around 110 degrees and the tick noise stays pretty quiet like a normal noise you would expect out of a motor this old. After i go to open it up and get load on the old girl it starts to tick real loud. Also when i open it up it doesnt have a problem getting up on plane but then it has no interest to rev over 3200 rpm +/- 200 rpm. From the searches i've done on the forum it sounds like I need to set my ignition timing and probably set the valve lash. What do you guys think? Please do not answer me with do a search as I have done all of that and dont need someone else to tell me to do it. Thanks in advance for your help.
