oldandintheway
- Jul 27, 2013
- 110
1973 Evinrude 135383M
So, JB created a great basic article, but the problems for most boat engine buyers is more complex.
Lots of articles refer to gang plugs - forget about it, they do not exist. I did Google for weeks.
Let's assume that you will use the battery power from your tow rig ?
Remove all the spark plugs and connect the wires to 1) outerspace, 2) grounded to the engine lift,
which is also grounded to the tow vehicle jumped to the tow vehicle.
Disable the the manual choke clamp at the engine and override to open.
Insert compression tool into each cylinder and read results, while jumping the positive cable to a jump to the red connection at the bottom of the solenoid.
I have purchased and read the owner's manual and SM
It is very complex for most of us to do a compression test on a new purchase. What can we do ?
Thanks
Ed
Thanks
Ed
