Re: Fuel pump
Never pumps up hard could be the squeeze bulb malfunctioning, a hole in the diaphragm or valve leaking in the fuel pump, or the carb float needles not seating properly.
SWAG would be a leaking valve in the fuel pump. I redid mine on a 90 of the vintage recently and don't know if I got the "new style" kit or not. If your new parts don't look like the old, part for part, you probably have a new kit. Pay close attention to how you take it apart so that you can get the suck and blow valves in their correct position in the pump housing, and get them put together properly.
My pump has 3 arrows cast into the pump housing which is in 3 pieces as I recall, which are there to help you get it back together correctly. Maybe your's does too.
While the hoses are disconnected, look inside and if cracked or pieces flaking, replace. They will cause problems elsewhere.
Mark
