I didn't know where to put this since it's about two different brands of motor and one is broken and one isn't.
I have a 1977 Johnson 15 horse that won't pump out water. I'm assuming it's the impeller since it's never been changed. It was my dad's motor. The second motor is a 2000 115 horse Mercury that I just bought used. The Mercury runs fine and spits out water like a racehorse however, as I've been reading about impellers I've read you should change yours about every 3 years or 300 hours. So I thought since it's over a decade old it probably also needs an impeller.
I watched videos on how to change the impeller and it seems pretty simple. Drop the lower unit, change out the impeller, put the lower unit back on.
My questions are:
1.) Should I change the impeller and water pump on the 15 horse? Should I do the same for the Mercury or just the impeller?
2.) How many people change their own impeller/water pumps? Is it easy?
3.) If you change your impeller should you always change the water pump also?
4.) How frequently do you change your impellers and water pumps?
5.) What's the cheapest place to buy impellers and water pumps?
My questions are:
