Well it's been kinda a tough year. Did a bunch of general maintenance and tuning and thought I had this boat perfect for another fun season and it did the following:
please follow my long winded story if you care.
Last four trips the same thing happened:
start great, putt around and also on plane runs with great performance for 3 or so hours. boating at all speeds, no stalling, just normal ops. Try to come to the dock and it would die when throttled down to idle. This happened repeatedly on four straight trips. I tried a different carb, that I had ready rebuilt, even went so far as to replace fuel.
Still same results. Checked timing and idle screws....etc. No change, the problem always manifested after a few hours and always seemed related to the shifting electronics.
So I went in to remove the ESA and all the wires and the ballast resistor that I installed when the breakerless mallory went in. My plan was to clean all the connections and make sure there wasn't a corroded wire or something.
Lo and behold the Ballast resistor was in terrible shape, actually the ceramic was broken in half.
Eureka, go get a new one and replace. The drive was down still from the last trip so after re-installing the ESA and related stuff I fired it up, seemed to be running great. Ready to go prove it.
BOOM! No tilt. just clicks. I think it's coincidental, and not related to the ballast resistor replacement. but?
Recheck all connections and they are good. (maybe I will do this again). Replaced one of the solenoids (up) same results. Looked at the 2 50 amp fuses and one of them looked suspect, actually had a chunk of solder on the side of it like it got hot. replaced it. same results.
This tilt system luckily has been working great for 6 seasons, but now I'm on the beach again.
The only thing I can think that was different about how I used it is that I ran it down a bit hard against the stop after last trip. I usually try to let it drop by gravity until it rests into the intermediate, but this time I tapped the switch down to get there and it thunked pretty good.
So now I need to continue to error check this thing and I'm wondering what should be my next step.
Is there a way to check the tilt motor without removing it?
Should I remove the tilt gear and try to run the motor free?
I'm pretty careful about the trunions being greased and the oil in the tilt clutch but I will verify. I'm going to take off the gear and see how free it lifts by hand.
Are there any other suggestions?
What if the down solenoid went out. Would that stop the up circuit from working?
When the motor get's ran hard to the stop what are the possible failures?
Thanks for reading and thanks for commenting.
