Live-liner
- Sep 19, 2012
- 74
Good Morning,
Could someone tell me a good way to clean, and "bench test" my heat exchanger. The manual tells me how to test while installed in the boat, but I want to bench test.
I read somewhere on this forum that acetone can be used for testing instead of pressure. I also read that an acid could be used to clean (not sure if thats a good idea), the manual says to use a brush in the tubes.
As always, I appreciate everyones help
Dave
Hi,
so this is the 4" heat exchanger on a 1986 Mercruiser 3.7 190. I just took off end caps and the inside of the tubes is nice and clean and clear. Looking down the raw water inlet and outlet, I can see some debris and scaling, etc. I have backflushed the unit and it doesnt seem to dislodge. What could I fill and soak it with to make sure the seawater side is clean. I can only imagine that any scaling or debris would be insulating the tubes and not giving 100% of the intended cooling.
I also would like to verify that none of the tubes are leaking.
Thanks
Dave
Hi,
Thanks
