Been fighting my 1977 Johnson Stinger 75 HP with a bogging problem for a while now. I've got a running 1977 Evinrude 70 HP that I've been swapping both ignition and gas parts with no luck (stator, timing base, power pack, carbs, fuel pump, gas tank, etc). Timing should be right, plates are set right, carbs are clean and float set right, etc. Spark jumps 2" gap on all three wires. Engine bored to 3.020 and rebuilt ... 125 psi on all three cylinders.
Last time out during WO bogging and the cover/air silencer removed, my partner looked into the carbs and noticed that the middle carb seemed to have too much fuel and the other two seemed to not have enough. When I got home and removed the carbs I noticed that the middle carb didn't have an extension [straw, pin, rod, restrictor, or whatever it's called] verticle piece to the ceiling like the other two. All pics I can find of other middle carbs seem to have this part. I'm not a carb expert, but I could see where if this piece is missing it might allow too much suction/fuel for it and rob the other two carbs. {When I temporarily swapped the Evinrude 70hp carbs last year it still bogged, but the part numbers are different}
So should my middle carb (387906) have this verticle through piece? If so, what is it called? I see where no kit or diagram refers to this piece! Thanx.
