170freedom
- Nov 3, 2009
- 135
Ok-
So I'm in the proccess of converting a 19' Rhodes sailboat into a diesel powered Launch. I thought I would share my build to anyone here that might be interested in doing some sort of custom build. It started as a old 19' Rhodes sailboat with a foldable keel and a 10 hp Ducati Marine diesel engine mated to a Hurth gear that I had laying around. I stripped the hull down, and cut out the center board and all the keel components. The seats are molded in and they have been removed also. I also removed 5' of the forward cabin area to open up the floor space and to accomodate the forward bench seating. I had to build a custom keel that would accomadate the prop shaft tube. Since this hull will only be doing 12-16 knots, the keel will help with the steering/tracking at these speeds. I removed all the old flooring and the rotten floor support spars. After the proper engine angle was established, I built engine beds, and new floor spars, and tied them all together with epoxy and glass. At this point, engine is installed, prop shaft is installed, and the rudder is installed. I just built the floor out of 3/4 marine doug fir plywood. I ripped the sheets down to 4" strips, stained them with a Bombay Mohagany stain, then they were sealed using a 2 part epoxy with a uv additive. I just got done building the engine cover, and the rear seating. Due to the rediculous amount of rain that we have had down here in Pensacola my progress has slowed a bit. Will post pics as soon as I can make them upload.
