trisonic1980
- Jul 7, 2013
- 3
I have had issues last few weeks with the fuel system. First I replaced the fuel/ water filter and bracket. Went out in boat and noticed instead of 4200 rpm were down too 3800 at wot. Then ran out of fuel and switch to second tank and fuel not pumping to filter. Replaced all fuel lines in boat. Replaced fuel pump. still not pumping. check filter was bad so replaced it again. boat fired right up. lake tested yesterday. still loss of wot. I replaced filter with a walmart brand since boat parts are always mail order where I live. Do y'all think the aftermarket fuel/water filter is staving the engine of fuel? also had the points cleaned before lost of wot by a mechanic. could that cause lost of wot?
Thanks
Thanks
