Well, the symptoms are:
- In the spring before splash cranked and spun like a dream.
- After sitting at the dock for some time the outboard turned slow to crank. But cranked properly every few tries.
- During summer it got worse and more rare to crank properly and finally impossible. The boat was used just a few times for short trips.
What I know:
- Charge voltage is non-existent. I'd expect 13,5 V or more and what I measured was the battery voltage raising only a little with engine on. Battery voltage had dropped to 12,2 V before recharging.
- Solenoid is suspicious. It has been immersed before, and during tests measured a high resistance once in off-position.
- I can pull-start the engine well enough.
- What I have tried:
* Reconditioning all connections.
* Start booster connected to battery.
* Start booster connected to solenoid hot post and engine ground.
* Jumper cables from battery to engine ground and solenoid hot post, both with booster connected and without.
* Jumper cables from battery to engine ground and starter positive, both with and without booster.
* Recharged battery.
* Jumper cables from recharged battery to engine ground and solenoid hot post.
* Jumper cables from recharged battery to starter ground and starter positive.
What am I left with but a bad starter? Could a starter turn sour on its own? I'll measure voltage drop across connections and amperage draw from starter once I'll have to boat on the trailer again and a helper.
What I know:
