Re: flooring a boat
My Lake Erie charter captain buddy, with a 28' Marinette, covered his deck with white "StarBoard". The original teak was to difficult to keep clean and the StarBoard just hoses off in a minute. Might want to look at the added weight, because the StarBoard seem heavy - just in case your boat is already stern heavy.
My son purchased a boat in which the P.O. replaced the floor and foamed between the stringers. The foam was saturated with water and after tearing out the floor and wet foam his boat was several hundred pounds lighter. You might check under the floor once you get it up to see if you have a similar issue.
erie_guy
Port Clinton, OH
