lowbukboat
- Aug 11, 2013
- 6
Hi guys,
New guy here.Have a couple questions.This is my first time owning a boat.I have an old 16ft aluminum unit with a 20R69B Johnson on it.Problem is when i rotate the handle and line up the red dot into the start position...i apply the choke and give it some pulls on the rope and it will never start.If i rotate the handle in between the start and fast position and give it a pull it will start. Once it starts i can work the throttle and it will run fine.(keep in mind this is all in a tub of water).If i try to back down the throttle to where it is a nice idle it seems that the vibration from the engine just causes it to jiggle till it backs off and shuts down.Then i can restart it the same way..Now before i dive into this i would like to know how the positions on the handle are supposed to work.I noticed it has a shift and a slow position.If i rotate it backwards past the start position to either the shift or slow position it just shuts off.The lean rich linkage is also broken.Any insight would be great and much appreciated..Thanks in advance
