Hey all,
New Boater here, I need some suggestions to look at after my new boat died out on water today.
Here's the history: Just purchased a 1971 Fiberform, I replaced the starter and the carb and had her out running several times last week. Unfortunately, the gas gauge is bad and she ran out of fuel last time out. To make matters worse, I hadn't gotten around to siphoning out any old particle filled gas before I took her out the 1st week, so I'm sure some sediment ran through. After filling up and taking her back out today, took forever to start up but when she did, ran fine for a while, then all of a sudden at medium throttle, engine just died without warning. Engine turns over just fine and there's still plenty of fuel left in the tank, just won't start up now.
I'm thinking the fuel filter and fuel/water separater may be clogged or fuel lines perhaps? Hoping it's not the fuel pump.
If there's any ideas or suggestions on where to start I'd be extremely thankful! I'm new at the DIYer stuff but I read the fuel filter is relatively easy to replace. So long as that's the likely problem, I'll give it a go.
Thanks!
Thanks!
