Key west Tom
- Jun 5, 2005
- 32
I have this 1996 V6 that the over heat alarm sounds sometimes when you slow down to idle. As soon as I increase speed alittle the alarm turns off. I have a hard time beliveing it is overheating becouse AS SOON as I speed the engine up the alarm turns off, I would think any increase in water flow would take some time to cool off the motor.
Is the alarm a temp sender or a pressure sensor? this just started this two trip ago and before the last trip out I replaced the water pump. still the alarm sounds.
One more thing, the charging system over charges but it has been doing that for along time guess I have to replace both regulators as it still overcharges when I disconnect either regulator.
