I was having uses with the boat bogging down/surging so I decided to rebuild the carb. After the rebuild I took it out once and it ran fine. The next outing it ran for an hour then starting bogging down then wouldn't start after being off for 30 minutes. I have since gotten it to start a few times but it would die after 1-2 minutes. Now it will not start at all.
As a side question that is probably totally stupid. Why do you need muffs on this boat when running out of the water since it is a closed cooling system?
Thanks
Thanks
