1988 Force 50hp outboard
Slowly working on repairing this engine. First time working on an outboard. I have fresh gas/oil mixture. Cleaned carb. Replaced float needle. Adjusted float. Cleaned fuel filter at fuel pump. Replaced fuel pump diaphragm. Adjusted air mix screw 1 1/4 turns out from lightly seated. Idle screw out 1 1/2 from lightly seated. Both plugs have good spark. Compression is supposed to be between 130-150. I tested it at between 110-120, so a little low but it's an old boat.
I took this video of it running. I know it prob could be numerous things, but thought I would post it to see anyway.
Boat motor - YouTube
thanks in advance for any help
