Capnkirkpatrick
- Aug 10, 2013
- 11
I'm reviving an old Galaxie with a Mercruiser 470 I/O. The motor seems to be in pretty good shape-it hasn't been started since 1990, but it's only got 140 hours on it and it looks pretty good...The trim wiring seems to have rotted out, but that's my next worry. First I want to try to start the thing. I have a new battery, and besides the main battery cables, there were red and black lines in the battery compartment-both look like they go to different sides of what I thought was the starter solenoid (although it's on the opposite side of the motor as the starter, so maybe it's the trim solenoid). Anyway, when I hook those wires up, the battery terminals get super hot. The lead cable connector on the red battery lead to the starter began to melt. I disconnected everything, charged the battery, pulled the rotten trim wires (which I think were shorting things out) and tried it again. Still hot, although I left it on for a much shorter time. So I'm thinking now that the starter might be shorting out? Anyway, I'm looking for a wiring diagram for a 470, maybe one that can explain what looks like it used to be a fusible link to the ignition wiring, and a fuse across the red and black terminals...
I can't tell what color this thing that looks like a fusible link used to be. I think my next move is to disconnect the starter and put a multimeter across it. Should be open, or pretty high resistance, right?
Can anybody point me to such a wiring diagram, or offer suggestions on troubleshooting this system?
Thanks,
-Dave
Thanks,
-Dave
