115mirrocraft
- May 29, 2011
- 20
Im in trouble now. after unsuccessfully trying to wire in a 5pin tachometer harness to more than likely the wrong style tach. I was going to take my 5 year old fishing. no go. motor would not trim up. i just get a clicking noise. pump sounds like it will work if i push he button down. but cant make it to the lake without transom saver on. thought it was just the battery but after charging it. and also running the boat in driveway motor still will not trim up. so not the battery. trim pump also only has one solenoid and pump does not have any markings for me to try and even order new solenoid if that is the problem. any help greatly appreciated. This has happened before but was always low battery. not the case this time had battery charger on it and tried it with my jump pack.
