1973 Evinrude 135. The service manual calls for timing to be set at 22 degrees with engine speed of 4300 to 4600 rpm (in gear). Is this considered the WOT setting? If so, then using your timing method, I would set the time at 18 degrees, correct? Also...I read somewhere that If I don't ground the plug wires for cyl's 2,3,&4 during the test, I WILL damage the ignition system. Is this true? Thank you for your time and expertise. Geezer.
