capttwb136
- Nov 22, 2005
- 18
I have a 2003 Mercury 60HP 2 stroke motor and can't find the warning horn/buzzer. Is it located in the remote control box? Or is it in the wiring inside the console? I'd like to see if it is getting 12 volts when I turn the key on. It will sound when I ground the overheat sensor wire in the motor, but not sound at all when I turn the key. I tried to listen under the console while it was buzzing, but I can't determine where it is. Some guys disconnect theirs, could one of you guys tell me where you disconnected it? Thanks, Tom
