Hi
I have got 3-cylinder Evinrude 50hp 4-stroke engine from around 2000 model year. Lower end was replaced by earlier owner after collision to a rock etc. However, engine did not start after repair.
I checked there is continuous spark and and injectors are supplying fuel to all cylinders as long as engine is cranked. Engine occassionally bangs to exhaust, but doesn't start running.
Compression pressure is only 5,5 bar evenly on all cylinders. However, when testing with compressed air, there seems to be no leakage from valves when they are closed, and piston rings neither leak pressure abnormally. I think the valve timing may be incorrectly adjusted.
The engine has timing chain under engine, so it's harder job to disassemble completely.
I see that the cam sprockets have a "top" marking and arrow, and they are facing upwards at the same time. Should some of the cylinders be at TDC at the same time, or how to determine if the timing is correct or even close to correct setting?
Thanks for advise in advance.
-Vili
-Vili
