JackBronson
- Jun 4, 2012
- 170
Last year I purchased a boat for the primary purpose of towing to the local lakes to do some skiing and tubing, with an occasional ride out to Salem Harbor mixed in. The boat did not come with a swim platform, so the way to climb aboard after jumping in was via the outdrive. We all got good at that, but early on I knew this boat needed a platform, and it had to be teak to match the boat's vintage (and the fact that there are a few teak accents on her, like the ski well cover and the bow cupholder). Here in the Boston area there aren't a lot of teak swim platforms kicking around on CL, so it took me about 6 months to find one. I chased the guy for two weeks because it was reasonably priced, was exactly the size I needed, and I didn't want to lose it. Paid $200 for it plus $10 for a single step swing down ladder that later on I realized I can't use.
Anyway, the platform had been coated with a solid color orange stain, like you might put on a shed or a picnic table. So, with some help from my son, I put a lot of time into stripping that all off. Citri-Strip worked well, with scrapers initially and then Scotch scrub pads to get it out of the grainy areas. Overall it took about 10 hours to strip it. Here is a shot mid-strip, with my son trying to brush the dust off his shirt.
Then hit it with the palm sander and 100 grit paper (yes some will think that may be too much, but I knew this would be a one time thing to get the wood nice and smooth) and it came out pretty good.
Next step was to scrub it with acid, so I bought the crystal oxalic acid product from West Marine. Liberally soaked the platform with it and scrubbed it with a stiff plastic bristle brush from Home Depot. MAN what a difference! A lot of crap came off the platform from the acid. It looked so good after that, however the cleaning also exposed areas that still had stain on them, so back to the citri-strip and the scrub pads. After a while of that I gave up and declared it good enough. Lightly sanded a couple of more areas that had gotten a little "furry" from the acid wash.
Lastly was three coats of teak oil.
This is the finished result (ignore the ladder for now - that comes into play later):
