Re: Seized Steering
Hold on a minute
if the tilt tube is turning then get a big tube on the spanners and just make sure your holding the tilt tube nut good and proper.
then simply push down on the big bar /tube for the steering cable, there is no way it can sieze to the steel, its
only an alloy material and would shear rather than sieze.
something just dont add up on this .
take a pic and show us what your trying to turn and what exactly your holding. !!!!!
a 15 inch spanner aint gonna do much good anyway, need a lot longer than that.
get 2 nice big bits of tube, 3 ft long and simply turn them off, wont even be a struggle if the bars are decent length.
I had a 6 footer on a tilt tube recently and that was well stuck, but it was not the steering cable nut !!!!!!
they come off easy enough.
get stuck into it, you need to get realy angry with it,...:frusty:
(just pretend its the mother in Laws neck your snapping and you will get it undone easy
ound
phill....
