gm280
- Jun 26, 2011
- 14,593
Hello everybody, ont new to iboat forums but I do have a new question for the educated folks on here on older trolling motors. I recently bought an old Motor Guide III foot controlled trolling motor and as usual completely tore it apart for refurbishing. The motor was completely perfect without one drop of water in that section. In fact nearly everything was in pretty good condition except for two things. The first was the steering cable which believe it or not is still available, but I managed to cut out the end that was rusted through and rebuild it back to like new condition. So with the steering cable now shorten about 3" to 4" all is again like new. The second issue was the three position switch on the side of the foot pedal. The toggle post was snapped off. Looking at it it looks like a simple DPDT center off toggle switch. BUT it is certainly not. This switch has internal setup to make it very unusual and a simple DPDT center off switch will not work. That brings me to my actual question. What function does this switch actual do. Is it a three position speed switch? There is no OFF position but beyond that I just don't know without an original wiring diagram of how it works. Now that is near impossible to find because of its age. Does anybody know or remember what the three positions actually do? Thanks for any assistance and replies. I have everything nearly ready to reassemble and it will look like new again and function like new also...at least once I understand the three positions do so I can wire it correctly.
