I 'm building a swim platform and found a bunch of pin holes in the epoxy/fiberglass that I need to fill/seal before priming and painting. What's going to be the best way to fill the pin holes?
I tried coating the pin holes with epoxy, but it didn't work as they just came back when I got to their level, they didn't get filled in, just covered up, epoxy too thick. Then I tried epoxy thinned with acetone, but found the same thing, the holes were not filled. It seems that the holes are being filled with sanding residue that I can't blow out with an air compressor, some of the holes clean out, but many of them remain filled with white sanding residue. I can dig some of fit out with a sharp tool, but it's not totally cleaning the pin holes. I have a feeling the sanding residue is sticking in the holes, like it's clogging the sand paper.
I was thinking of painting on some primer and scrubbing it in with my fingers (gloved), but not sure that will work since the holes are plugged with white sanding residue. :faint2:
Any ideas...?????
Any ideas...?????
