davidwjacob
- Aug 25, 2008
- 28
Hello,
I got this boat a few months ago back from someone i sold it to 3 years ago. they messed up the prop and the tilt on the motor and then just pulled it from the water and had it wrapped and winterized by the marina. this was almost 3 years ago.
If the boat was winterized (which he claims it was professionally) , what do i need to do to summerize it?
I just recently got the boat back and i found a prop for it, but when i hook the battery up to it and try to just kick it to see if the motor will turn over it just clunks like this in this video. Im wondering if its just the cyl are stuck from sitting for 3 years, so i pulled the plugs and i have squirted wd40 into the cyl then put the plugs back in to let them sit. but do you think from the sound of the noise its making when i try to start it , that its the motor? or maybe something in the starter?
VID 20130808 190856 030 - YouTube
also is there anywhere to hook a rachet up to the motor to try to crank it over by hand?
Im slowly learning about this stuff from here , Im mechanically inclined i like to think, but im not a mechanic, if that makes sense.
Thanks in advance for any help
Dave
Dave
