bajatrouble
- Jul 12, 2013
- 9
I have an '86 Baja islander with an alpha 1 Outdrive, and having trouble with the trim. I checked the switch and it seems fine. I have power at the switch on the top wire when I hit the button up and on the bottom wire when I hit it down. Also all the time on the middle wire. The trailer button works fine. When o/d is down it will trim all the way up when holding trailer button. Now for the prob.! When I push down on the trim down switch it will work about 1/2 the time not every time, the pump will at least make a click noise ( so when it clicks but won't trim I release a try again until it works. The trim up however does nothing at all. No noises no clicks no movement. But like I said the trailer button will bring it up fine. Any thoughts?
