I have a 1999 Bayliner with 3.0L Mercruiser. I recently had it tuned up and a new carburetor top put on. It starts, idles and runs geat but will die after 10 - 45 minuets of running for no reason. It is as if the ignition is just turned off, like the safety switch lanyard is tripped (which it isn't). I try to start it again and it will crank but not start. After 1 - 2 hours of lettting it sit, it will start up again and run fine for another 10 - 45 minuets before dieing.
I believe this is an electrical issue, due to the way it just dies - no sputtering like a gas issue - and it starts and runs fine again after a period of time. I also believe it might be either the electronic ignition module or the coil, because it runs great until it heats up (which is indicative of electronic component heat failure).
I would like to get some feedback from others who may have experieced such an issue or can offer some advice before I start replacing components and hopeing it fixes the problem.
Your comments are appreciated.
