The OMC 175 engine is a Ford 302 engine block and everything I know and read suggests this should be 5 quarts oil capacity. But, the Dip stick is stamped "Capacity 4 quarts." My maintenance manual doesn't really address this either.
I have real concern for this as I have been having radical oil pressure readings on the gauge and the other day, when the dip stick read 1 quart low, I experienced a lifter that started rattling. If the capacity is really 5 quarts, I was running with 2 quarts low which would explain a lot of my concern.
Does anyone have a reading about this? Is the capacity 5 quarts, or 4 quarts. I feel reasonably confident it is the correct dip stick.....but who knows.
Thanks
Thanks
